Old 09-13-2011, 07:42 PM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
Stock timing on my Hi-Po 289 engine is 40 degrees BTDC, stock compression is 10.0:1. With the vintage Paxton I've found it necessary to reduce the timing by just 7 degrees to 33 BTDC to eliminate detonation. In the winter, or when the airt temp is under 70 degrees, I can get by with 36 total timing advance.
Z.
'65 K code Mustang
'66 Galaxie 500
