Turn Signal / High Beam Pod not Secure
Hi Bob:
I had the dash partially out the other day, thus I let the column down. When I put it back together, I noticed the turn signal / high beam pod was not tight. What do I need to do?
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
