Old 09-17-2011, 06:36 AM
jojoegen jojoegen is offline
Hi Marco.the bracket that attached the side pipe fell off.When I checked the side pipe it has alot of movement up and down so I saw the connection to the tubes at slip joint really loose.The guy that assembled the car put a screw through the slip joint so it won't slide off.Has to be a better way.Also thought of the spring connection holding parts together also allowing some movement at the slip joint so it won't crack from stress.Don't know.Also a leak at this joint won't help engine compartment heat which I had a problem with.NEED HELP,JOHN
