Old 02-08-2002, 02:19 PM
poorboy poorboy is offline
Rich;
Nothing to it. Put the car on stands. Disconnect drive shaft at rear end, disconnect brake lines, rear trailing arms (both ends), rearend center brace, upper shock mounting plate (4 1/4" bolts per side), put floor jack under center section, remove 4 1/2" cap screws, lower to floor. I think you have already taken the shocks off, so skip that step.
Poorboy
