Old 09-20-2011, 11:19 PM
fastmerc fastmerc is offline
Default Stuff not on ebay! Stuffed in Storage.
Cleaning out storage, found some pieces tonight that I didn't know I had....all need new homes!
C8AE-9441-C intake gaskets (2). Still have yellow paint marks (part number) on gaskets. Tunnel port 427.
Felpro Intake gasket set #1246 for CJ/SCJ 428 Still in wrapper from 1988.
One set of C3AE/C4AE metal head gaskets .041" compressed I believe. NOS Ford. Man, did these things used to be cheap!
Aluminum std vol 428CJ oil pump. 60K miles on it....1/4 mile at a time on the streets of San Jose!
C8AX-D cams. One in Ford tube, one in a cam grinder box. Some slight surface rust from storage on one of the bearing surface/cam lobe. .600" lift Cam used at the 68 Winter Nat's where the CJ Mustangs premiered (I think).
428CJ harmonic balancer, good rubber! (three bolt style 68+) Heavier outer ring. Still neutral balance.
Oil drippers, two or three different types.
"Mercury" FE tall valve covers, circa 1966. That would make someone look twice on a Cobra!
70-71 429 CJ/SCJ #208A intake gaskets- not in wrapper.
Large in/out 1969/1970 Cobra Jet top loader, needs brass. This is the short trans out of a Mustang/Cougar.
I guess I'm close to needing a body to hide all this stuff in.....ugh! Drop me an email if you can help!
Steve
