  #113 (permalink)
Old 09-21-2011, 01:18 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
I have been fine tuning my webers, especially trying to lean out the whole thing, because it was smelling too much of gas and using a lot of it..
Large main jets and idel jets are fine and make things run, because they mask any other deficiencies in the choice of air jets.
I went to smaller jets , 55 idle and 145 main and worked myself up from there.
At idle the A/F ratio came down to 13.5 on idle, but went very lean when starting to move.
So I removed the 120 idle air jet and went to a 100, which improved things a lot. I subsequently installed a self made 80 ( drilled out a 60 idle holder) idle holder air and things got in line quite well.
I noticed a slight lean hole when accelerating, so decided to open the pump Jets up from 50 to 60.Good result.
The main jets at 145 were a little too rich and power and acceleration was slightly hampered, at 13.5 to 14 A/F ratio. Since I wanted to achieve a A/F ratio of 12.8, which is for maximum power I installed a 155 main jet. The air jet is 120 and maintains the 12.8 ratio up to max rev , that is 6200 rpm.
The whole thing is slightly on the rich side, but I just thing that it has to be like that to make these engines run to its best.
Definitely Webers give these engines the crisp and inmediate response other carburetors don’t. I always had problems with Holleys sputtering when taking fast corners or when breaking hard (killing the engine in the process). Whit the Webers this is now an absolute race engine, with incredible torque and reving capabilities ( I have an aluminum flywheel) and a sound to make you absolutely happy.
I have a friend who is a Rally champion here in the Balearics( with Ford Cosworths and the like), and who had a chance to drive in McLaren F1 and several top Ferrari models. He said that the sensation of brute power and of blood draining acceleration he had in my Cobra topped anything he had driven before.
If you snap the gas pedal open from 1500-2000 rpm , first you go sideways, the back trying to overtake the front by the right side. You correct for that and there you go off like a rocket.
Fantastic sensation. You better have some good driving experience doing that or you can destroy yourself.
Anyway, my concept of supercars has changed a lot. For sheer fun I only need my Weber equipped Cobra, nothing else.
Nothing sounds better than a Cobra in a Tunnel !
