Guy's,
Just did a F/I changeover using the weber manifold and webers (tried to keep the look) but upgrade the fuel system, anyway to get back to your question, I used the Mallory fuel filter and 140gph pump that was already installed to the vehicle, I made a 250ml surge tank with a second inline filter attached directly to a 044 Bosch OEM fuel pump (flows to 700hp) to a fuel pressure regulator set at 35lbs. It's a 427 s/o with 428 crank, rods, crower stage 5 hyd cam, shaft mounted roller rockers, ported heads, in 70 fastback, 4 speed, 3.89 rear end and it puts out 394.6hp at rear wheels. Good Luck,
But I am going back to a 2x4 setup, the injection seemed to tame the engine too much, it lost its mongrel feeling that all good Big Blocks have.
Darryl
What's behind is Loosing!!!! Ha Ha
