Fuel pressure and volume are key concerns here -- Bosch makes a good pump that Tom Kirkham turned me on to , that you need a couple of metric fittings to use then you are online.
You need to have a conversation with the mfr of the system and have engine info ready.
the higher the pressure, the smaller injector you can use to a certain point.
old 86-93 fords used 39PSI , the new GM stuff runs at 58-60 PSI -- there are variables all over the place.
Steve
