Many thanks gents,
As a rank royal rookie in this area, I had to read it thrice to ensure I understood what I thought I was understanding, eventually me thinks I gets it.
But just in case... can you pls confirm what I've concluded.
Here's the low down -
I'm specking my car out with a return fuel line for EFI.
But the standard pump with the car is only good for a carbie, 5psi?.
I don't have the engine yet and wont have for some time, and will probably need to make a decision on this sooner rather than later.
Engine Parameters - FE - mild build, cammed mostly for street.
Cubes may be anywhere from 427 up to 482 stroker. Thus anywhere b/w 500-600hp & tq.
So from what I understand - Wolbor or Bosch that can get me at or just over 50psi is the way to go?
Or
I should just plumb the return line and then wait till the Engine details are confirmed and then go from there?
Your thoughts?
Thanks again
