09-22-2011, 01:48 PM
Cobra Make, Engine: SPF#0760
Clicking from the tach........?
First I'd pull the power supply from the new volt meter you installed and see if the Tach still clicks...
Then check the plug on the tach that you didn't loosen it while pulling on the red wires...
You sure it's not a relay..likr the start inhibit relay clicking? Put you fingers on the relays and sutne the key...feel anything?
Blas
SPFWiringDiagrams@Comcast.net
