Old 09-23-2011, 12:54 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Basically-----no
Do you have oil galleys to the lifters? some FE blocks do , some don't--
If you have oil pressure to them , they will go over 100,000 miles
If you don't have oil galleys to them, you might consider doing it---I used to make up a couple of tubes down the lifter valley and run dash 3 lines across to the opposite side to a hole I drilled into the lifter bosses--- worked super with no problems--
These days you can get lifters with a pressure feed to the roller
