Old 09-23-2011, 02:58 PM
FWB's Avatar
FWB FWB is offline
LUCAS WIPER MOTOR
  • Terminal Connections
  • #1 Earth = Black
  • #2 Park = Black/Green
  • #3 2nd Speed = Yellow
  • #4 Ignition Power In = Green
  • #5 1st Speed = Green/Red
doesn't coincide with the color wires you have. however the connector (plastic) is correct but you don't seem to have the ground connected.
have you done a continuity on the wires going to the switch. can you verify low , high and hot?
on the motor the yellow seems to be high speed the blue low and the red hot.
do you have a wire hiding up above the motor?
Fred B
