you must have an issue at the switch. like i said that plastic connector is the park switch all the leads will have to run thru there to park. if the leads from the motor are plugged into the connector like the pic i posted, and you determine what wire from the switch, control what event, then connect as per the pin-out i posted of the other side of the connector and it would work.....if it doesn't you might have a bad motor or switch. i read where the park mechanism can be shorted by wiring up incorrectly..
Fred B
