Originally Posted by patrickt
What about Fuse #8? Check that for the low beams. If fuses 7 and 8 are good, then it pretty much has to be either the dimmer relay, the dimmer switch, or a connection between them. Try wiggling the connections and plicking the relay with your finger while you simultaneously hit the dimmer switch with the car ON. If all of that fails, I would replace the dimmer relay with VW Part # 111 941 583.
Patrickt:
I have low beams, fuses 7 and 8 are good. Also, I have a Triumph column. I'm sure I knocked something loose, I will crawl underneith tomorrow.
Jeff
