Originally Posted by patrickt
OK, with the Triumph column there is no dimmer relay, so don't bother replacing it.  Here's the wiring on it -- you must have pulled one slightly loose.
Patrickt, thank you. I must have missed this. I looked at the assy. manual, wiring diagram, connection diagram and adendums. PM me if you need to.
BTW my car is in the 100-334 car series, I don't know how applicable the above diagram is.
Jeff
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
Reason: Added information
