That's pretty close to what I have. I'm using and Eagle rotating assembly, with SRP pistons. Rod clearances are exactly where they should be.
Still using the Dartp pro-1 heads, with some porting. My hydraulic roller cam is pretty big, with a lot of lift, and really makes cylinder pressure in the upper rpm ranges.
Dynamic compression is about 8.4. That works fine here at altitude. But at lower altitudes it's a problem. Since you live at sea level, I would shoot for about 8.4. It won't go up michy, and can easily go down.
On the chassis dyno, I'm making 510 hp.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
