Why can't you get it on a rack or do a compression check on the car? If the buyer will not allow this, run away. Also, he should let you drive it, with him, for a good 20 minutes if you are serious.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
