Old 09-26-2011, 03:32 PM
dallas_'s Avatar
dallas_ dallas_ is offline
Originally Posted by Wbulk View Post
I have read the tech sheets on Featherfill and Slicksand but they don't address the issue if the gelcoat was sanded through in spots.
The other issue I need some help on is both the tech sheets for Featherfill and Slicksand say you can spray the base coat right over them without a sealer. Does anyone have experience with this?
Wayne
What he said.
Slicksand will adhere just fine if you have sanded thru the gelcoat. No need to spray epoxy first.
And yes, you can lay the base directly over those high build primers if you haven't sanded thru them.
You will probably end up laying on another coat of high build primer anyway after you block sand the first time. It's not uncommon to have to do that a few times, depending on how good the body is to begin with.
