Old 09-26-2011, 11:09 PM
tin-man's Avatar
tin-man tin-man is offline
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Originally Posted by RICK LAKE View Post
tin man John what kind of system do you have??
Vacuum booster with master attached?
Vacuum booster with aux vacuum pump and engine vacuum?
Hydro boost with power steering?
Electrical pump like old GM Teves design. Pump runs when pressure gets below 1,200 pounds.
Do you have any pictures? Some system make noise, others you should hear nothing.
If there is an electric pump for hydro pressure under the master assembly, you can rubber insolate it to quiet the noise. Rap the pump in fire proof cloth and leave loose to quiet down noise. It is normal for electric pump systems to start running when key is turned on if pressure is not within spec.
Hydro booster you should hear nothing at all except if you are turning parking lot speed and hit the steering limiters and load the system. Most hydro system pumps run about 2-300 psi.
If you are running a electric vacuum pump, you can switch to a vacuum assist one like on the older diesels that run off a little belt. They are quiet and make about 15 hg of pressure with the motor running.
Unless you are racing the car, manual brakes should work fine with a 2,700 car and 11" rotors in the front. More info would help. Rick L.
Hi Rick, The only thing I have in this respect is the picture, attached and a bill stating 12 volt vacuum pump, I have asked the installer what type of system I have and I'm still waiting for a reply. Just so you know I am in China and the Cobra is in Fullerton California getting some corrections made to it after I drove 78 miles and it stopped working. I have a post on that topic. When I hear back I will respond. Cheers, John, AKA, tin-man
Be well, drive fast, live long
