09-26-2011, 11:23 PM
AZ
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Originally Posted by RICK LAKE
Tin -man First name would be nice. Switch to a hydro boost setup. You can find them in some of the Rod mag's. You already have the PS system, it's easy to swap over the rest. If you want better brakes this is the way to go. The only thing is to add a P/S cooler under the front of the car on the radiator support to help control fluid temps. I run a P/S system with a Sweet rack. Works great, like you bad shoulder from baseball. No 90 mph any more. Lucky if I can thrown it 20'. Don't raise arm over head either. Anyway If you want more info, goggle it or I will get the people to talk to you. It's a bolt in system. The brakes will put you through the windshield in the beginning. You don't need a heavy foot. 1,400 -2,000 psi of pressure the system uses and this make the brakes stop quick. You might need a pedal stop under the dash. The pedal travel is only about 2". Just a thought. You built a car the way you need it to address you needs. It's just as fast as and 5 or 6 speed. I do have a ashtray in my car, and the other half quit smoking. Rick L.
Rick, this sounds great and I will surely consider what you are recommending when I finally get my Cobra back. I'm guessing you have been down the path of the torn rotor cuff, not pleasant and never quite really heals. When I was test driving the SPF Cobra at Hillbank and turned into the parking space the shoulder rotor cuff popped, thus the power stearing option was first thing I asked for. Then the power breaks. Cheers, John, AKA, tin-man
Be well, drive fast, live long
