Thanks Ben, obviously i haven't seen the tank before, I'm actually surprised at how small it appears to be, do you know what capacity it is ?
The construction looks quite tidy, do you know if it has any baffles, based on your comments, about the swirl pot I'm assuming minimal at best.
Whats the bracket on the side of the tank for ?
Is it to mount a Bosch style pump maybe ?
Your rear upper shock mounts definitely stick out further than mine, an improvement i suspect, as i couldn't get the bolts out until i removed the body. 10mm difference is about all it would have taken.
Good idea about the anti chip, i never even thought of it, but i can do myself as i always intended to remove the body.
I suspect your right about the upper front shock mount, yours look angled towards the bottom mount, mine are vertical, meaning the rod end is on an angle to the bolt and the force towards the rear mount face.
Fantastic photos Ben, I'll PM you about a get together.
