Old 09-29-2011, 08:56 AM
elmariachi elmariachi is offline
Regardless of which slave you use and how it's set up, make sure you don't use any rubber lines. The best setup is a hard line from the master and a flexible braided stub line in the last few inches to permit flex between the body and driveline. A rubber line will expand under heat from the exhaust and reduce line pressure, resulting in a soft or no pedal.
