Old 09-30-2011, 08:29 AM
snakehunter's Avatar
snakehunter snakehunter is offline
Cobra Make, Engine: CSX4158, alloy body. The Watersnake!
Default Fuel tank vent hose(s) ?
When we got 4158, the fuel tank filler neck had a welded 3/8 nipple near the top, with a 3/8 hose drop for an overflow or vent.
However it also had an an 8 fitting on the tank itself, with a 1/2" hose looped around itself and zip tied to the frame. Hose was just pushed on to the fitting and clamped - which seems a little rigged.
Are these both vents? Seems like the AN fitting should connect to the filler vent itself, rather than 2 lines.
