Originally Posted by Car Nut
Apparently you have a vacuum pump which supplies sufficent vacuum to a vacuum operated power brake booster.
They make noise, that's normal.
Seems you called it correctly, I have been informed what I have is
a vacuum pump to give the brake booster vacuum. Being the case then the noise I should get used to, right?
Cheers, John AKA, tin-man
