SCOF has the instructions.
The bearing is retained by a circlip and must be pressed out/in of the hub. You will need a new axle retaining nut on the axle where it passes through the hub. These are "one time" use type nuts and must be torqued to 175 Lb/Ft.
What is your chassis number?
rick@autoventureusa.net
Reason: added
