10-02-2011, 04:50 PM
Vic
Ben
I see you have attached close to the tank that nice blue annodiser Earl fuel filter.
It was the bain of my early car's running as I believe the filter can't flow enough for an injected system. Suggest you take it off and replace it with a standard Ford or Holden filter that will flow freely.
My car would run for a while and then slowly starve whilst even at 60 kph. Pulling over the car would generally idle and I learnt to switch off and prime the lines to get any further driving.
Once I switched to a larger filter all my issues went away.
I too had my G-Force tank modified and went away from an external Bosch 044 to a BA Falcon in tank pump set up - so much neater.
Good luck.
Steve
slowy
