  #21 (permalink)
Old 10-05-2011, 09:41 AM
LMH's Avatar
LMH LMH is offline
Originally Posted by chatterbox5333 View Post
I hosed the nut down with PB Blaster last night and again this morning. Tonight I will heat the nut and use an impact wrench on it. I also picked up the new axle nut from Ford. It is the stacked nut encased in sheetmetal type. Is one enough or should I reassemble using a second as a jam nut?
I've seen that done before but the Ford nut is designed to not back off. The stack acts as jamb nuts, so I think it should only have the new nuts installed one per side.
Alba gu brąth
