Old 10-06-2011, 04:38 AM
joyridin''s Avatar
joyridin' joyridin' is offline
I ran the aluminum version on my big block truck. I know a few people that used them for racing also. They work quite well. Pro-Comp used to have a stainless set. They were scrap. Many people had problems with galling and the rockers would seize. The aluminum set has roller bearings, so this wasn't an issue.
I would run them again on a moderate engine. I personally wouldn't use them for any super high revving application or anything for racing. That is just my 2 cents.
I ran one of their water pumps also. It was about 1/2 the price of a comparable aluminum version. Never had a single problem.
It is funny...if most of you actually saw the facility where some of these various parts are being manufactured, you would keel over and die. I visit a company that manufactures roller lifters (the name has been mentioned on here before), another place that makes crankshafts and camshafts, another that makes blocks and heads, and various other parts. Most of them are dumps. Old crappy machines, temps running the parts, using cheap chinese tooling, buying whatever cheap metal they can find. The crankshaft manufacturer uses all forgings from china. I have no idea what the facility that manufactures Pro-Comp items looks like, but I doubt it could get a whole lot worse than some I've already seen right here in the USA.
