Old 10-06-2011, 08:40 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by BT SNAKE View Post
Thanks guys for the quick reply. My EFI is the Mass Flo Injection
System. I have a Magen pressure regulator with a gauge newly
Installed. When the engine is cranked the gauge shows zero. I was going to adjust it
When and if this darn thing runs. Believe me I have installed this system correctly. I have been over and over all the connections. It's pretty much a plug and play deal. As far as I can tell it's a good system. The customer service sucks though.
Jeff, I'll be giving you call. It's good to hear from you.
Hersh
This is the problem right here. When you first turn the key, the pump should run for a few seconds - like 5-10 sec. When you turn the key to start and the engine cranks over, the pump should run and bring fuel pressure up to 38psi. If that's not happening, the cylinders are not getting fuel.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
