Old 02-09-2002, 08:39 PM
JimsGems's Avatar
JimsGems JimsGems is offline
Cobra Make, Engine: '73 Jensen Healey Mk.I #13046
When all else fails give Maurice a call, he will likely have the answer, or can give you a educated WAG! Hey! What could it hurt.
Wiring can break internal to the wire coating but that just causes Grimmie's and intermittent problems, I have had a bad solenoid with a direct short to ground once upon a time. Re-Check your recent work and verify all wires are landed correctly and all the connectors are properly crimped and the conductivity verified. Good luck, these are the tough ones.
Jim Weatherford
Now, I'm powered by Lotus and garded by Lucas the Lord of Darkness.
