Thread: Winter Blues
Old 10-10-2011, 02:22 PM
Turbonut48 Turbonut48 is offline
Cobra Make, Engine: 1968 GT350, FFR Daytona Coupe
Definitely a Battery tender. Gas stabilizer and make sure the coolant is good for below freezing temps.
If its going to sit on concrete I would put down a sheet of plastic to reduce moisture coming up thru the concrete and condensing on the vehicle underside.
If its going to sit on the tires I overfill them by about 15-20 lbs so they dont flat spot. Otherwise block it up under the suspension.
Plastic bags in the tail pipes to keep out rodents or insects.
Pray for an early spring.
Good luck.
The Nut
AND a car cover.
Enough is enough. Too much is just right ( C.S )
