Old 10-10-2011, 09:48 PM
gene giambona gene giambona is offline
Cobra Make, Engine: SPF 1474: 482 CI stroked tunnel port 427 with dual quads.
Stan,
Take a look from inside the trunk of your car and you should be able to see the factory slits made for the shoulder harness in the fiberglass (generaly centered somewhere behind the driver and passenger seats just above the height of the frame support brace). The brace will be where you can mount those shoulder harnesses. The slits are covered by the carpeted area behind your seats. Try poking an awl from the trunk through the slits so you can get an idea where the cuts need to be made. Good Luck!
"Some things just get meaner as they get older"
.....Gumball Rally :-)
