Thanks CWizard...
It's getting to be that time of year when the bypass REALLY becomes usefull... Spring is another time, so if you don't get it done before too long, this is a good winter project for sure!
I drove #131 to work this morning and the temp outside was @50-55 degrees. I just slow the flow of
oil down through the cooler and it heats up nicely! Right now, it's about 70-75 degrees outside, so when I go grab some lunch, I'll open the cooler flow back up a bit (I usually run at about 75% flow through the cooler when it's "comfortable" but not "Africa-hot" outside)... At this setting the
oil temp runs right with the water temp....
It's an awesome system...
