I just returned from the shop that is pressing the wheel bearing. The mechanic showed me the failed parts and explained why they failed. The hub diameter was too small. The hub was spinning inside the inner race of the bearing instead of the bearing spinning. The wear on the hub was clear proof that when it was originally pressed together, it never seated correctly. Anyone ever see this issue before?
