Sorry to be gone so long, but when Travis and Dana delivered the car I disappearred into the garage and went to work. Replaced
oil pan(with problems), fluid fills found problems, had to redo entire alternator bracketing and belt. trans leak and hydraulic clutch leaks repaired engine wiring and plumbing almost done. MCOO arrived today so will be visiting the SOS. Redid some brake issues. Still need to prime engine
oil circuit, fill with coolant, prime fuel lines, install distributor and connect HEI and tach. probably fire on Fri. or Sat. Also need to remount shoes and rough in suspension settings so it will drive to chassis shop for final alignment.
