Thread: No gas???
Old 02-10-2002, 09:14 AM
WestCoastBill WestCoastBill is offline
Gordon, in case you haven't. Consider what you may be doing as far as breaking in a new cam properly (you said everything is new). I've found it's very important to make sure everything is ready to go before firing up a new motor in order to insure proper break in procedures can be followed. Also dumping gas down a carb can result in to much gas on the cylinder walls. Not good for any motor. Last thing to consider is all that gas combined with incorrect timing, a tight valve, a misplaced plug wire, and/or most likely no air cleaner can build a "not so nice" fire. These are all things I've experienced in my youth and if not news to you hopefully someone else might benefit. Have fun, be safe, not always in that order though. Bill
