Old 10-14-2011, 12:16 PM
PNJSNAK's Avatar
PNJSNAK PNJSNAK is offline
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Aaron:
Can you post pictures of your radiator setup?
Hoses, mounting bracket, etc.
I did what the manual said, although I went with a special Griffith Radiator I ordered direct from the mfg. I had the necks put in spec position and direction and had pet cocks added both top and bottom of the radiator.
When I get close to 100 or above, the front end is very unstable in my opinion. It feels like it is just floating. I always wondered if the angle forward of the radiator causes lift. The originals and all others since have radiators tilted back. I also believe I do not get good airflow over the raddiator and hense cause alot of my high temps. I have a 16" puller fan mounted to the radiator. But I am also wondering if I should add a shroud behind tyhe radiator and the fan mounted to it. I wonder if such a shroud and fan combination is already available from a specialty supplier.
Also, what size radiator are you using?
Jim
OhioCobraClub.com
