  #26 (permalink)
Old 10-15-2011, 06:41 PM
blykins blykins is offline
I think blykins undercuts all the major FE builders on this forum. Brent, can you build her a 450HP, reliable, street based turnkey 428FE for under, say, ten grand?
Turn-key? I'd have to figure it up and see. If you wanted to use a true 428 block, it would be pushing it. My turn-key stuff is truly turn-key though....while others lack fuel lines, plug wires, PCV valves, blah blah blah. I'd say it would be closer to $11-12k depending on what options are ordered.
I would be very apprehensive about any FE build for $3-4k though. The prep and machining alone for my FE builds (on the block alone) usually runs $700-800 by itself.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
