Hi Ron
I`m very impressed at the way you are putting your car together.Congrats, it`s always pleasing to see the owners finishing with the correct period look.By the way you are able to lay your screen back as per your Bill Stowe picture.The body is slotted and the s/s cover is much bigger so even when your screen is laid back the slot is covered.
Re the long range tank I think just a dummy fit is better as I`m scared the extra fuel weight will effect the handling and even cause bottoming out as the spring might not be up to it.The standard tank holds enough to get you around.
Enjoy your car and thank you for choosing the superformance mk2.
Ross
