  #420 (permalink)
Old 10-18-2011, 10:10 AM
tkb289's Avatar
tkb289 tkb289 is offline
Allen,
Thanks for the photo. The FIA side pipes are different setup, but correct me if I am wrong, a similar configuration with attachment to the header collector and one rubber isolated mount near the outlet, correct?
Was able to work on the exhaust last night. So far we have shortened the header collector 1" to bring the head pipe up closer to the car, probably have a bit more to take off. We have the muffler set between the frame outriggers and spaced about 3/4" from the floor, so the location of the muffler inlet, ultimately sets the length of the collector. Will have a rubber isolated hanger that attaches to the tail pipe near the output side of the muffler. I have a variety of hangers and will try to use an existing hole in the frame. Want to have the entire setup slip fit and bolted together for serviceability and modification down the road. Will post some pictures as things progress.
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
