  #29 (permalink)
Old 10-20-2011, 03:05 PM
patrickt patrickt is offline
Originally Posted by Tony Radford View Post
I charged the battery back up and now the starter relay simply chatters. I can't even get her to turn over. All of the accessories work fine, headlights are bright. Charger indicates the battery is at full charge.
And if you put jumper cables from your other car on that apparently fully charged battery and try cranking it does it then crank over or does it continue to click and chatter from the solenoid?
