Originally Posted by Tony Radford
Have to get back to you on that one.
My thinking is that if your fully charged battery will not crank it, but it cranks nicely with jumper cables from your wife's Toyota, then either your battery is faulty or the connections at the battery are faulty. If it cranks nicely when you have the negative battery cable clamped on something on your Cobra other than the negative battery post (like a spot on the head or the like) but it doesn't crank when it's clamped to the negative battery post on your Cobra, then a bad ground connection is the culprit.
