63 galaxie 428 questions
I have a 63 galaxie box top that i'm restoring and I have a 428 industrial short block that I want to build for my car. I'm converting my car over to a BW T-10 4 speed and the problem i'm having is bellhousing choices. Do I need to get the original style long starter bellhousing or can I use one of my pickup truck FE bellhousings and have the narrow bolt pattern holes drilled and tapped? Can I use a 428 flywheel with the old style bellhousing? Will I run into clearance(depth) issues with the truck style bellhousing? I'd rather not buy an aftermarket bellhousing and have a scatter sheild. Thanks. Bob
