Just curious why you want to use the T10 in it .... unless it`s because you already have one . I have a 63 1/2 427 Galaxie and the original T10 was replaced with a toploader ( original owner raced it and exploded the T10 ) . The T10 `s aren`t that strong and will come apart on you under hard use . The toploaders hold up much better .
Since you`re replacing the engine with a 428 , originality is already lost and no one will see that you have a toploader unless they go under the car .
You might also go to the FE Forum and do a search on that subject and see if anything comes up .
