Old 10-23-2011, 08:23 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Thanks John,
She is a very well built car with some nice touches for sure. We did wake that small block up and I do like the rumble on idle. Remember it has a fairly large cam so loves a little RPM. If you are going to play she needs at least 1500 to 2K to be real snappy and will pull well into the 5,500 rev limiter setting you wanted.
I hope you picked up a few lottery tickets while your good luck streak is hot. Finding the bad roller rockers before they let loose did save you a few bucks and lots of frustration. Have fun and don't get to crazy. Jeff C
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
