Anybody have pictures/part number of this diode and how to install in when using a one wire alternator.
I have the same issue sometimes. Only when it is warmed up. Never when it is cold. I.E. if I start it up, pull it into the driveway it will shut right of with no problem. After it is warmed up, sometimes it will not shut off.
If I hold the brake on and use the clutch to kill it, no problem cranking it back up even after a month as setting there will not run the battery down. So it must be feed back from a power source.
TIA
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
