Hey All,
I have a set of the Erson roller rockers and had to remove the baffels inside the valve covers. I have the Ford Motorsport breathers and it was work out ok until the foam in the breather got saturated with
oil. Now I have this annoying leak from the breather caused by not having a baffle inside the valve cover.
I wanted to find out what you guys are doing to fix this problem. One thought is to put the baffles back and double up on the gasket to provide clearance.
If I do that, does anyone know what the rivet is called is holding the baffle in place in side the valve cover.
