Old 10-24-2011, 11:15 AM
patrickt patrickt is offline
Originally Posted by priobe View Post
Patrick,
Are you running single gaskets. I have the same covers but when I switched to the black rubber gasket from the cork had a clearance issue.
So I removed the baffle. Now I am wanting to put it back and mod the baffle.
I first ran corks, but then changed them over to black rubber because of leaks. That pic is of the valve covers right after I put the 3m Weatherstripping stuff on them, and right before I put the black rubber gaskets on them. Then what I do now is when I remove the cover I smear a bead of "open gear" grease on the head where the rubber gasket contacts it and I have no oil leaks whatsoever and the covers are easy to remove for valve adjustments.
