I went with TP tools to keep it american mde. You ca go to habor frieght for half the price, made in china. Be sure to use a water trap on your air line so that you do not clog your media as stated in other posts. I also use mu shop vac to clear the air inside the cabinet. A provition is on the side of the blast cabinet for it, you just need to attach the hose from the vac and duct tape it or purchase an adapter. They do use a high volume of air so make sure your compressor is lage enough. At least a sixty gallon compressor, anything smaller and it will run constantly and may not provide a steady pressure.
