Ya, having to drive a few miles at 3:30 AM to get Wi-Fi is a pain in the arse.
Yellar; you have to use regular grommets, about an 1"-1'/4 for the front and 1" for the rears. You cut the grommets down the middle leaving you two O" rings from each grommet. Then VERY carefully use "Crazy glue" that has been made to actually glue to rubber! The front grommets will stretch to fit the angle of the front tubes.
On the rear I don't use any glue. This way you can pull the rubber- grommets away from the body when you want to wax the car, then push them back.
I get them from Kimball-Midwest, Col's, Oh. Mc Master Carr should have them too.
Sorry I used my last four, but if you have any trouble contacting Kimball I'll get you there phone and salesman on next visit!
DV
